Dataman 448Pro2 Quick Start Guide
  • Install the master into the ZIF socket, lower justified.
  • Click “DEVICE” on the menu bar.
  • Click “Select EPROM/Flash by ID”.
  • Read the message, if displayed and click “Yes”.
  • If more that one device has the same ID, select your device from the list.
  • Click the “Read” icon. (Wait until done), Note the checksum.
  • Remove the master.
  • Insert the blank EPROM.
  • Select the blank EPROM if is different from the master EPROM.
  • Click the “Program” icon.
  • A program dialog box is displayed. Click “Yes” to select the default values. (Wait until done)
  • Click the “Verify” icon. (Wait until done)
  • The programmed EPROM is now ready to use.
  • Click the “Load” icon
  • Browse to the correct directory.
  • Select the correct file type.
  • Select the correct file.
  • Click Open.
  • Click the “Save” icon
  • Select the correct path for the file.
  • Enter the file name.
  • Select the file format.
  • Click “Save” and the file transferred to the hard drive.
