Flash programmers are used to program a wide variety of flash devices available in many different packages. Flash memory is a non-volatile memory type which can be electrically erased and reprogrammed repeatedly. Dataman flash programmers support a wide range of the most popular devices in use today - with new devices being added monthly. Flash support includes 28Fxxx, 29Cxxx, 29Fxxx, 29BVxxx, 29LVxxx, 29Wxxx, 49Fxxx series, from 256Kbit to 8Gbit, with 8/16 bit data width and full support for LV series. All Dataman flash programmers come with a 30 day money back guarantee, comprehensive warranty and life-time technical support. | |
Dataman S6 Compact USB Programmer USB powered universal 48-pin chip programmer with compact dimensions and minimal weight. Dataman S6 can program without the need for a family-specific module, giving you the freedom to choose the optimal device for your design... |
Dataman 48Pro2C Super Fast Universal ISP Programmer Super fast universal 48-pin programmer with ISP capabilities and USB 2.0 connectivity. Dataman 48Pro2C can program without the need for a family-specific module, giving you the freedom to choose the optimal device for your design... |
Dataman 48Pro2 Super Fast Universal ISP Programmer Super fast universal 48-pin programmer with ISP capabilities and USB 2.0 connectivity. Dataman 48Pro2 can program without the need for a family-specific module, giving you the freedom to choose the optimal device for your design... |
Dataman 48Pro2AP Super Fast Industrial Universal Programmer Super fast industrial universal programmer with ISP capabilities and USB 2.0 connectivity. The 48Pro2AP is built to meet the demands of production programming with automated handlers and ATE machines... |
Dataman 448Pro2 Super Fast Gang ISP Production Programmer Super fast universal ISP gang programmer with four independent 48-pin ZIF sockets and USB 2.0 connectivity. Concurrent programming options combine with device insertion tests and a user friendly interface to give higher programming yields and reduced failure rates... |
Dataman 448Pro2AP Super Fast Industrial Gang Programmer Super fast industrial gang programmer with four independent modules, ISP capabilities and USB 2.0 connectivity. The 448Pro2AP is built to meet the demands of high volume production programming with automated handlers and ATE machines... |
Dataman 848Pro2 Super Fast Stand-Alone Programmer Super fast stand-alone gang programmer with eight independent 48-pin ZIF sockets and USB 2.0 connectivity. Concurrent programming options combine with device insertion tests and a user friendly interface to give higher programming yields and reduced failure rates... |
