PIC Programmer
PIC programmers are used to program Microchip's range of programmable interface controllers (PICs). PIC devices are general purpose microcontrollers usually used in stand-alone applications to perform simple logic, timing and input/output control. They provide a solution in between single chip computers and the use of separate logic and timer chips in an application. Dataman PIC programmers support a wide range of the most popular devices in use today - with new devices being added monthly. PIC support includes PIC10xxx, PIC12xxx, PIC16xxx, PIC17Cxxx, PIC18xxx, PIC24xxx, dsPIC and the latest PIC32xxx series. All Dataman PIC programmers come with a 30 day money back guarantee, comprehensive 3 year warranty and life-time technical support.
 Dataman S6 Dataman S6 Compact USB Programmer
USB powered universal 48-pin chip programmer with compact dimensions and minimal weight. Dataman S6 can program without the need for a family-specific module, giving you the freedom to choose the optimal device for your design...
 Dataman 48Pro2C Dataman 48Pro2C Super Fast Universal ISP Programmer
Super fast universal 48-pin programmer with ISP capabilities and USB 2.0 connectivity. Dataman 48Pro2C can program without the need for a family-specific module, giving you the freedom to choose the optimal device for your design...
 Dataman 48Pro2 Dataman 48Pro2 Super Fast Universal ISP Programmer
Super fast universal 48-pin programmer with ISP capabilities and USB 2.0 connectivity. Dataman 48Pro2 can program without the need for a family-specific module, giving you the freedom to choose the optimal device for your design...
 Dataman 48Pro2AP Dataman 48Pro2AP Super Fast Industrial Universal Programmer
Super fast industrial universal programmer with ISP capabilities and USB 2.0 connectivity. The 48Pro2AP is built to meet the demands of production programming with automated handlers and ATE machines...
Dataman 448Pro2  Dataman 448Pro2 Super Fast Gang ISP Production Programmer
Super fast universal ISP gang programmer with four independent 48-pin ZIF sockets and USB 2.0 connectivity. Concurrent programming options combine with device insertion tests and a user friendly interface to give higher programming yields and reduced failure rates...
 Dataman 448Pro2AP Dataman 448Pro2AP Super Fast Industrial Gang Programmer
Super fast industrial gang programmer with four independent modules, ISP capabilities and USB 2.0 connectivity. The 448Pro2AP is built to meet the demands of high volume production programming with automated handlers and ATE machines...
 Dataman 848Pro2 Dataman 848Pro2 Super Fast Stand-Alone Programmer
Super fast stand-alone gang programmer with eight independent 48-pin ZIF sockets and USB 2.0 connectivity. Concurrent programming options combine with device insertion tests and a user friendly interface to give higher programming yields and reduced failure rates...
